I’m curious if anyone has experienced what just happened to me on my run.
If so, do you know the cause, and if not, does this portend a major problem with my phone?
Here is the sequence of what happened.
I’m listening to a podcast during my run.
Suddenly, silence.
I assume the podcast just stopped, so I retrieved my phone from my pocket only to be confronted with the passcode screen. “No problem,” I thought. “I’ll just put in my passcode.”
I put in my passcode. It is not accepted. I tried three more times. My passcode is not accepted.
Realizing if I try x number of times without success, I’ll be permanently locked out, I decided to reboot the phone.
Once rebooted, I get the message, “iPhone is not available. Try again in 1 minute.”
Figuring this is an error, I reboot two more times. Same result.
I rebooted again, only this time I waited the prescribed 1 minute.
Indeed! I’m waiting for the Ultra to show up in the Apple Store so I can see it in person before deciding if I think it will be “appropriate” for business casual wear at the office.
The “… not available. Try again in 1 minute…” part of this should not be concerning; that’s something the phone does after repeated failed unlock attempts. The wait time increases if you don’t get it right.
I’ve had the same thing happen when running in rain or wet snow. In fact, it registered so many failed false unlock attempts in my pocket that I had to wait for an hour or so to even attempt to get back in.
This is the bit that would concern me. The phone wasn’t frozen, it was allowing you to enter your code and on the assumption you typed it in correctly, it claimed your code was wrong.
A possibility but the phone was accepting the digit input; it was just not recognizing the passcode. I’ve had a few weird things lately on my phone–it blocked the number of one of my contacts and it switched my default calendar in settings. I’m not sure what is going on. Gremlins?
Noting that with multiple touch-screen devices, I’ve seen that accumulated sweat/grease can cause the screen to not recognize input properly. The solution is shutting the device down for a minute so it doesn’t register input, and cleaning the screen.
Maybe a microfiber cloth in a plastic pouch in case this happens again?
