"Power User Thumb," or, is it time for a Moonlander?
I think this is right. I almost went with Beck’s suggestion to buy a used one and then changed my mind at the last minute of the eBay auction. Spending money on a different keyboard won’t solve this issue — changing my habits will.
I’m continuing to mess around with layout customization. I’ve just solved another problem I’ve been having: arrow-key navigation. I created a keyboard layer for arrow-key navigation under WASD and swap to that in a couple of ways.
Here’s one problematic habit I can’t seem to find a solution for: cmd+w to close windows and tabs. Is there any ergonomic one-handed way to do that? Or does everyone use right-hand cmd and left-handed w?
I know you should use different hands for modifier and letter, but I use homerow mods and specifically made sure that w and t are on the left side, so I can browse the web with the right hand on the trackpad and the left hand on the keyboard :slight_smile:
Cmd w for me is middle finger for cmd and ring finger of the same hand for w. This is easy enough for me.
That being said, you could have a layer where you remap a single key to the combination cmd+w.
Also, I use a vim extension for safari (vimari) which allows to use single keystrokes for common actions such as closing tabs or moving to the next one.
Ahhh, use Vim :slight_smile:
You are an obsidian fan, right?
Obsidian has a very solid vim plugin, give it a try.
It comes with an ergonomic remapping of the arrow keys :wink:
