I thought about it for some time. Frist I try to take some (lazy) precautions steps.
Never run a Mac OS in Admin mode.
Always update system
I save the most important files peridically on offline drives ( i have two different one so if by change the ransomedware is already active as I backup files the other disc is not affected and I loose only recent files)
Chose the apps I install with cousion,
Try not to use software the is integrating deep in the system as this might open another attack vector.
I guess as Iām not a target if high value this should be sufficient
I wouldnāt worry about its age. Patrick will certainly update it at some point, but until then, running it under Rosetta is not going to be a resource drain.
Patrick is extremely bright (ābrilliantā might be a better word) and I never noticed a difference in system performance running it on an Intel Mac. The Apple Silicon Macs are so much faster and more efficient that Iād be surprised if there was any noticeable difference at all in running the Intel version.
Back to the code itself: my understanding is that the app looks for types of behavior which indicate that code is being obfuscated/encrypted. While this can sometimes cause false positives (I believe that I ran into a few instances where using the compression tool xz made the app warn me), it is simple enough to respond to an alert and say āNo, that process is OK, allow it.ā
As such, there probably isnāt much need for the code to be updated because it is searching for heuristics (I believe thatās the correct word) which are far less likely to change over time.
Thatās my opinion, which I offer for free and with no guarantees. Iād certainly prefer to run RansomWhere than not, even with its imperfections.
