I would appreciate recommendations for a basic timeline/gant chart type of application that is not overly complex and that ideally will integrate with either OmniFocus or Things 3. NOTE: I would prefer to continue using Things 3 but IF the application is compelling and will integrate with OF, I’d consider moving back to OF.
I am NOT a project manager but I do manage a lot of projects across teams and departments but only at a high level. I do not deal with resources, etc. Accordingly, I need a relatively simple way to visualize and modify projects across time and adjust them as needed.
Preferences but not requirements:
- An application rather than web-based
- Integrates with either OF or Things 3 (back and forth updates between the two apps)
- A reasonable purchase price or subscription. By reasonable I mean a purchase price of $300 or less or an annual subscription of no more than $100.
- Ability to export in several formats
Ideas? I found this site rating applications but as you can see based on who wrote it that though helpful, is not entirely objective.
Recommendations?
