Reputable sites for preowned apple products?
Hi all I’m in the market possibly for an M1 Mac mini but want to see if I can spend less than $700. Anyone know of any reputable sites that sell preowned?
I would go to OWC / MacSales but M1 Mac minis seem to be holding onto their value. They haven’t been out very long. You’re a couple hundred low.
EDIT: I was able to get a well-spec’d Intel Mac mini that runs macOS Monterey for $319.
What is your RAM and SSD requirement?
I used Gazelle, but looks like they only sell MacBooks.
It’s $700 on the apple website directly which is where I got that price
I don’t need a lot of SSD as I can do external but RAM I need a fair bit. I’m looking to run a game I play on it and different programs at the same time. I’m currently using a 2016 MacBook Pro hooked up to external monitor. It works but does lag and get hot so I just need something that runs a lot better than what I have
A Mac with 8GB memory and 256GB storage is of no use to me. You left out all requirements except price from your initial post.
Costco sells new ones (M1/8/256) for $670 but sometimes with additional discounts. Currently out of stock. I know you wanted preowned but I thought it was worth mentioning. :grinning:
You could keep an eye on Apple’s refurbished site.
Perhaps setting up a visual ping to alert you to changes.
Thanks for the resources! I’ll keep an eye out
