That’s amazing Tonny. Can you just explain the different options for me?
Sure
Save URL for later
- Will save an URL for later
Fetch URL
- Will present a list of all saved URLs & let you choose one to open in Safari
Fetch several URLs
- Will present a list of all saved URLs & let you choose as many URLs to open in Safari
NB. The shortcut will let you know that this option MUST be run either from Safari share sheet OR in slide-over / side-by-side mode to function properly
Remove URL
- Will present a list of all saved URLs & let you remove one or several URLs from list
Excellent! Thanks Tonny, that is amazing.
Is it possible at all to save more than one URL in Safari at a time? Because I have about 155 open tabs right now to save for later
I’ve been looking into that, as well, so far without any success.
I fear that Safari for iOS is sandboxed sufficiently for it to be impossible.
If it’s possible through JavaScript, though, we might be able to… but I hope some JS capable reader reads this and maybe try to combine this shortcut with Scriptable
Thanks Tonny, otherwise doing it one at a time could work also. Thanks my friend
No worries - you’re more than welcome
