Typically my understanding is that when taking a screenshot on iOS it shows the screenshot in the bottom left hand corner. Is there a setting I pushed wrong? Anybody else have this issue too?
No, there is no setting to control this. Take a restart, if that does not work take a force restart. If that does not work, then backup and reset all settings.
Ok will do thanks I’ll report back if all is resolved.
Are you getting the screenshot and just missing the little “markup” window?
Took me awhile to remember to just tap the home button while holding down…
I force restarted and it works now, thanks!
