I have an older Seiko (SII) Smart Label Printer 200 that I use occasionally.
I’d like to connect it to my Macbook (M1 PRO). I was able to install Smart Label Creator v1.6.0.0 but I cannot locate the correct driver for the label printer.
Any suggestions? If I’m just out of luck, so be it. It’s not a critical situation, but it would be nice if I could get it working.
You can send Seiko a message, if you select “Printer” on the upper left of this Website and there “Legacy Products”.
Maybe they could help you with that.
Yes. I’ve been there, done that. No reply (yet) but I was hoping someone here might have a non-Seiko solution. Something like VueScan for LabelPrinters
