I would like to connect my new MacbBook Pro to 2 monitors. What do you recommend for hardware (e.g. docks) and software to make this happen?
What model year is your MacBook Pro?
If it’s a recent model with Thunderbolt 3 ports then you’ll need two USB-C to HDMI/DisplayPort/VGA cable, depending on what connections you have on your monitors. This will be the cheapest way but means you now have three cables to remove when you want to move the MacBook. A Thunderbolt Dock will be more expensive but will run both monitors plugged into a dock and give you a single cable to plug into your MacBook with should also provide power.
Thanks for your help.
