I know this is incredibly simple, so simple that even a caveman could do it (with all due respect to cavemen everywhere!) but for the life of me, I can’t figure this out.
I found a Shortcut I want to use with Apple Notes. It’s very simple, create a new note with the current date in my Journal folder.
The problem is that as I have tested this several all times the date format right, the note is created and the date format is correct. BUT, every time I run the Shortcut today to test it, it adds a month to the date format. As you can see I’m up to the “17th” month.
Checking Apple’s documentation, you can see the the lowercase m is for minutes, while the uppercase M is for month. Therefore, you need to use the uppercase M.
