Should I go for it?
Should I go for it? It works right now on 7.1. I found the 7.5 disks and I’m feeling a little worried.
Do you have 7.1 installation disk(s) just in case?
Nope. This is a one one way trip.
I was on 7.1(.2?) for a looong time. Don’t remember the reasoning, but I didn’t want to upgrade to 7.5, but I ultimately jumped to 7.6.1 and stayed there until Sys9 (Sys8 looked weird to me and I remember early versions being buggy, so I stayed off it).
7.6 was great. You can get an entire Toast image of the install floppies at The Mac Repository.
I’d check with @ismh86 to see if he has them :wink:
