Today I successfully taught my Robot a skill to create PowerPoint slides for me and using my own template for this. To that end, I exported a file created in Keynote from my template which contained 15 slides (one each for each type of slide) in PowerPoint format and put it into a folder named Assets in my Obsidian vault. Then I asked the Robot to create a slide deck (I briefly described the content) and use that template as a starting point. It responded by saying that it had a skill to produce PowerPoint slides within Claude and that it would use it. When everything was done, I asked it to create a skill in the Obsidian vault that used everything it had learned in the process, and it duly did.
Having rewatched video 10 from the RAFG, I spotted that @MacSparky has a skill that is named keynote-slide-designer - so I wonder, David, whether you have indeed found a way to have your Robot design Keynote slides? If so, I am sure it will come up in one of the workshops (and I’ll wait patiently), but I just thought I should ask the question in advance to see whether anybody else has managed to do that, too, perhaps?
Many thanks for any help and suggestions!
