Sure! I use CSV files to track my time. I have the following shortcuts to make this easy:
A “function” shortcut that takes text input, adds a datestamp, and appends to a CSV file.
A shortcut for each time-tracking category. It sends predefined text to the function shortcut. I also have widgets and voice commands for these shortcuts: “Time Sleep”, “Time Jesus”, and so on.
The end result is a spreadsheet of time-tracking data. I then use an R script (I’m a data scientist) to mash the spreadsheet into a pretty visualisation of how I spent my time during the week.
The HomePod is most definitely getting better with time. I’ve also seen way more buy-in with my family but that is partly because we are already all-in with Apple Music.
I have almost 30 years of records in CSV files (actually TSV). I keep current records in the Notes app and transfer them to CSV files at the end of the month. On the Mac I use Unix scripts and Keyboard Maestro to search and manipulate the files. I haven’t found a great solution for iOS. CSV Touch comes the closest but it’s read only and hasn’t been updated in many years.
You could modify it very easily to use tab - ‘\t’ - instead of comma. I don’t create CSV with tabs so I don’t need that.
The prompt for whether to treat the first row as a header happens after the data is parsed. That’s an accident that you could easily fix. If you did you could add a switch for “use tabs instead of commas”.
Let us know how you get on.
Actually, anyone who modifies this. I might want your improvements.
(It’s perhaps notable I developed the parsing function in Scriptable and then transferred it to Drafts.)
I purchased a new HomePod from B&H Photo since the price has been reduced to $249. I put this one in my office along with one I had before and formed a stereo pair. Gotta say, it sounds really good! The stereo separation is great, and you can clearly distinguish left and right channels.
I’m torn between buying two Sonos speakers (same price as one HomePod) or spring for two HomePods. My problem is that I like the Alexa integration with the Sonos but I suspect that the HomePods have a little better sound than the Sonos. If I go with the HomePods I could just add a few Echo Dots around the house for Alexa related needs.
If any of you have a thought on this, I’m open to suggestions!
I think what you are suggesting makes the most sense – get the HomePods for the sound quality (they really sound good!), and use the Echo Dots for the Alexa integration.
