So Spotlight in macOS Tahoe is almost = Raycast/Alfred?
I don’t use any clipboard apps on iOS sorry. Until they’re properly usable I don’t want to bother.
Have any of you gotten the new spotlight to work to launch apps without having to go the extra step of entering the applications category? I find it incredibly frustrating that i cant just press cmd + space and launch an app. For instance “calc” used to show me the calculator, now its just a long list of files and emails.
You can add a shortcut to get to the “Applications” search directly
I don’t see these options. Are you not using Tahoe? Am I looking in the wrong place?
I am on Tahoe yes, and you are in the wrong place indeed! You need to go to Keyboard → Keyboard Shortcuts and select Spotlight from the sidebar.
Got it. Thanks for further explanation.
I don’t see Spotlight anywhere near Raycast or Alfred atm.
Like, I’m using Betterbird as my second mailclient for work. I don’t use it that often and I previously used Thunderbird.
When I open Spotlight I start typing …bird… and it doesnt find anything. I have to start with B.
This is just an example. Spotlight doesn’t find a ton of stuff the other two apps don’t have problems to find.
