Check out
For some cool tricks and tips.
FYI, the backtick key is the one just under the esc key on the mac keyboard.
My Favorite was Option Dropdown arrow to expand all of the folders in a folder
Check out
Thanks for sharing. I feel we don’t get as many trick and tips anymore from MPU. I liked the one that allows you to take between choices in system messages.
If you want tips and tricks you need to listen to the MacGeekGab podcast, from MacObserver.com. They’re up to episode 829, which had the following tips discussed in the 90-min episode:
They’re video recording the podcasts and putting them on YouTube, but I just listen to the podcast.
