State of Outliners in 2023
OmniOutliner is one of those apps that never really “clicked” for me. I’ve wanted to like it, but every time I use it I run into weird ways of doing things that seem unnatural. For example, create a new, blank document, you can resize the document just fine and everything works. Now add a column, and try to resize the new column to the left. You wind up with something that looks like this:
I love OmniFocus, and I’ve been an ardent fan of OmniGraffle since I first searched for a Mac Visio alternative back in '04 or so. But, honestly, what the heck where they thinking here?
I think it’s typical for the column divider to resize the column to the left of it, and to let you make the column too narrow if you want that. Numbers, for example, behaves the same way; it just doesn’t keep the table centered while resizing like OO.
I’m not saying that means you have to like OmniOutliner. I understand you probably dislike a lot more things about it.
P.S. I’ve been messing with OutlineEdit 3.0, mentioned above, and it’s a nice little app. I love that we have (IMO) at least three good options right now that are dedicated outliners, being actively developed, use local documents and each have their own perspective on outlining.
I use it as a spreadhseet for basic tables where I might want a tabular data where I’m not using fomrulas etc - purely for it’s ease of use of rearraning and moving lines up and down. I can’t state how much I use and like this feature! My day job involves a lot of prioritisation of items in tables, so being able to easily move items up and down the priority list as needed is excellent. I wish Excel or Numbers had the ability to easily move rows up or down but I can’t see this as a feature.
However, it has its quirks as stated.
Is anyone out there still using Workflowy? And, if so, what for?
In the same boat. The way I work/think/expect things to work, just never completely aligned with OO.
I would actually read the manual in the hopes of my learning how to do X/Y/Z, but since I use it periodically (albeit intensely at the time), I would always come back and find myself hitting sharp edges — and having to re-learn how it expects me to do things. And, unlike OF, I also found the syncing of documents to be less than intuitive.
It’s clearly a brilliant app — but personally, was always more of a struggle to use than I expected. Regardless, went all in on purchasing it on the Mac, and iOS — so will probably get a few more years out of it. Good to know there are other options, however.
It looks like the price for OutlineEdit in the US Mac App Store is now $19.90 (about a $10 drop).
It definitely has a very “Apple” feel to it! I can’t seem to turn numbering on (I.A.1. etc.) but that could be me. From the Outliner & Notes App for Mac - OutlineEdit 3 website
If you need something more “simple” but gets the job done, I find Cloud Outliner Pro to be rather good
Wanted to make sure y’all know about what, to me, seems to be the internet’s headquarters for people who like using and talking about outliner software:
https://www.outlinersoftware.com/
A bunch of great threads in the forums there.
Thanks for the mention! Also to note, check out the latest update to OutlineEdit 3 which was just released with a bunch of nice improvements: ‎OutlineEdit 3 – Outliner Notes on the Mac App Store
What’s New
This update improves usability & accessibility. It is recommended for all users.
⋅ Ready for the newest operating system versions
⋅ Hide item indicators
⋅ Category name labels and improved display of categories
⋅ High-contrast notes option
⋅ Unfold hoisted item group automatically
⋅ Shortcuts for easy traversal and selection of item groups
⋅ Improved plaintext import and export, from apps and files
⋅ Improved OPML import from specialty apps
⋅ Further performance improvements and bug fixes
Let me know any feedback.
Best,
Robin
This looks like a great app, but it doesn’t appear to have an iPad version; am I correct? I often switch between my Mac and iPad for writing-related work, so I need applications that work on both devices.
Otherwise, it looks like a great app!
I’ve had OmniOutliner click for me, but I’m in a corporate windows environment, and there is not one application that is a dedicated outliner I can find. Webapps, and Scrivener is all I can see, so instead struggle along with Microsoft Word.
I don’t think there is very much out there that will beat the extensive feature set of OmniOutliner
I would have thought if you One Note would be better than Word for outlining, if have access to that.
You could also look at Taskaid - although positioned as a task manager, is it a competent outliner?
I was thinking of dipping a toe back into the Windows world, but the lack of outlines is one factor that made me rethink. While there are some other Windows outlines out there they feel very expensive for what they are and not quite right. You could go and search or post on the Outliner forum that another member linked to
Agreed, I continuously try Onenote but its attempt at being a jack of all trades makes it a poor outlining tool. Definitely spoiled for choice in the Mac world. I’ll give Tasked a try, though I normally dislike web apps I think beggars can’t be choosers.
Workflowy (https://workflowy.com) is a fairly comprehensive and cross-platform solution.
Have you looked at InfoQube IM ? I don’t run Windows enough for me to explore it. The documentation is a little thin, but there are some interesting things you can do with it in top of outlining.
MLO isn’t strictly an outliner, but it scratched that itch for me years ago (I also used it before OF, also a pseudo-outliner…) Andrey’s a hard worker.
You can download it from the Mac app store - you don’t need to use the web app
Ditto for Dynalist. It’s what I’ve settled on for cross platform outlining needs. It’s robust and has a solid set of features.
As my primary requirement for an outline tool is to structure documents I use Scrivener! Its Binder gives me an overview of the structure and when it is wrong it is easy to move items about. In extremis Scrivener also has an Outline view not that I make much of that. There is also a Card view but like the outliner function if isn’t something I use often.
Here’s an outline (as it appears in Scrivener’s Binder) of notes on how best to present my data within Apple Health app to correltate certain events with others.
Screenshot 2023-10-02 at 09.33.20
A couple of things need adding to the outline: Use of AI, Data Mining with Weka. And the Data Extraction item should a) be split into two and b) the implementation specifics moved under Create Personal Dashboard — I’ll correct the typo later
Each one of those items will have text added to them to create a compelted document as part of my personal Requirements Elicitation for a suitable presentation tool.
@Glimfeather You’ve sent me down a rabbit hole, this might really work!
