I am searching for a mac/ios app to sync my todos in my calendar.
I would like an app where I can define starting and ending time for a task and it would appear in my calendar and not in app’s internal calendar (such as Things). I do think this is possible somehow using keyboard maestro (I think I saw a workflow with omnifocus), but I do not want to use keyboard maestro (I am not using it for anything else). I just want this feature to be a part of the app itself (Omnifocus 2 had this beautiful feature, but it has gone since then…).
I do think Todoist allow you to do it, but I really do not want to embark on another subscription-based software.
Basecamp (which I am currently testing), allow to create a multiday task and sync it in your calendar. Which is pretty good, but I cannot block a couple of hours with a task, just a day.
Do you know of any other options out there?
Thanks!
edit: the script for omnifocus I mentioned above was made by Rosemary Orchard
