Todoist iOS Add Task no longer works with dictation
For more than a year I’ve used a very simple iOS shortcut to add tasks in my car using Todoist. For one, it avoids the issue with Siri sometimes confusing “todoist” with “to do list”. I also use it as a building block to add lists of tasks.
I recently noticed that calling it up, Siri collected the task info but then said “I’m sorry but I can’t do this while you’re in the car”.
I finally found the time to sit down and see what’s going on. Now I’m confused whether this new behavior is caused by a recent Todois or iOS update…
Here’s the shortcut: !(https://i.imgur.com/GsveKVn.png)
Doesn’t get any simpler. Show When Run is disabled in the Todoist Add step details.
It works fine when I run the shortcut from clicking on it within Shortcuts. As expected, it shows a dialog to request the task name, then silently creates it, and ends the shortcut.
However, when I activate it by saying “Hey Siri, new task”, it prompts for the task name, then switches over to Todoist and shows me Todoist’s “create a new task” dialog with the title filled in, then sits there waiting for me to click the submit button.
!(https://i.imgur.com/iLjGZSd.jpg)
So no wonder it won’t work in the car as it’s waiting for conformation.
Any ideas?
