Thank you for the link – had a look, and that was my understanding of things (good to confirm).
It’s not a major issue, since splitting a part of the track, when placed immediately adjacent to one another, doesn’t make any difference to the playback – but it’s still a slight annoyance to my OCD tendencies that a split section, cannot be made whole again.
By way of example – I drop the scrubber at the end of a sentence, but before the [next] sentence that I want to remove. I split the section at that point. I move them apart a bit (as a visual aid, with “dead space” in between), and then follow along for the next few sentences, until I get to the end of those sentences that I want to remove – place the scrubber there, and split again.
I now have [section 1-to retain] (split) [section 2-to remove] (split) [section 3-to retain].
I continue and do a whole bunch of other things – making CMD-Z no longer possible.
I then return to sections 1-3 above.
It occurs to me, when listening again, that I placed the scrubber too close to the last sentence in [section 1], and I now have a nano-second of the audio that I want in [section 1], with it instead sitting “inside” [section 2].
So, what I want to do is “un-split” [section 1] and [section 2] >> thereby making it a single, whole section again, move the scrubber a smidgen along (to properly capture all the sound of that last sentence), and then split again into [section 1], [section 2-to remove] and [section 3].
This does not appear to be possible?
So the only option(?) is to effectively create a “new” split inside [section 2], to then capture that last nano-second of the sentence that belongs in [section 1], and place this “new” [section 1b] directly after [section 1] – and then delete [section 2], leaving [section 1] [section 1b] and [section 3].
Seems it would be far simpler to allow one to “unsplit”/re-merge? [section 1] and [section 2], as opposed to now having to split off additional part to compensate for an initial error on my part.
