Usb-c to HDMI *and* VGA adaptor
Hi all
Just wondering if anyone has any experience/advice in buying a usb-c to HDMI AND VGA adaptor. I don’t want anything like an entire hub (with bunches of other ports), just something as simple and transportable as possible. Preferably something that is not no-name-brand.
Thanks in advance.
Simon
I guess you want it for simplicity, not to use both ports simultaneously? I’m not sure such a thing exists. I just bought one of each, and an Ethernet one as well.
I found this brand to be good in terms of price, appearance and quality.
[USB C to HDMI Cable(4K@60Hz), uni USB Type-C to HDMI Cable [Thunderbolt 3 Compatible] for MacBook Pro 2018/2017, iPad Pro/MacBook Air 2018, Surface Book 2, Samsung S9, and More - Gray - 6FT/1.8m https://www.amazon.com/dp/B075V5JK36/ref=cm_sw_r_cp_api_i_gx7qCbE52MJKZ
thanks. that’s great.
Actually, this is the link I meant to post. It shows all dongles from UNI.
https://www.amazon.com/stores/node/16713715011?encoding=UTF8&field-lbr_brands_browse-bin=uni&ref=bl_dp_s_web_16713715011
The Mac Observer recently posted a link to an adapter that can do HDMI and VGA:
Thanks very much for your response.
