I am a big MagSafe fan and sad to see it gone particularly on the new MacBook Pro. I’ve been using a Volta XL and it’s been pretty great! Two drawbacks: 1) the light won’t indicate when the MacBook is fully charged 2) you need to take out the piece that connects to the usb c port with a small supplied spudger. Cable is high quality and disconnects just like a MagSafe cable should. Wish I had bought two. Anyone else using a MagSafe substitute or a Volta?
I bought some of these from Massdrop
They work with 30W 2018 MBA, but not
the 87W 2018 15” MBP
