Not sure what’s happening.
15" Macbook has been fine been running Catalina for 2 months.
Got a notification that there was a new system update, so I updated. (Now on 10.15.3)
Ever since the update, wifi has been extremely annoying.
Connection drops every 10 minutes, when it tries to reconnect, it keeps asking for the password every single time (treating it like the first time to see this network)
The only solution I have found that works almost instantly…is to turn the wifi off and then on again from my Apple Menu bar settings.
Thoughts? (fyi, nothing in my network setup has changed at all, no movements, wires, etc)
I tried all the options provided. Same. Works for a bit, disconnects, has a problem re-connecting on it’s own, until I physically turn on/off wifi from network settings.
So I hd a similar issue. Is it possible your wireless access point can’t handle that many devices connected to it? Upgrading to an eero 18 months ago seemed to have solved my problem with this, which Apple devices seem to be more susceptible to this issue.
