Hi, I have received an email which consists of 4 pages and each one has part of a map/plan on it. Each page is A4.
What I need to do is to somehow combine those 4 pages into one large map in a single PDF page. Clearly it will be bigger than A4 (A2?).
In the office I would have printed out the separate pages and then sellotaped them together to form the larger map/plan and look at it. But I can’t print from home.
Assuming you’re on a Mac, you could create a new, blank document in Pages, convert it to a Page Layout (File > Convert to Page Layout), then drag and drop the PDFs into this new document. You can then rearrange the imported documents and export to a PDF (File > Export to PDF).
If you know ImageMagick, it can do that.
A quicker route I would do is convert them to PNG using Preview, then you could combine them in Your choice of app, eg Pages.
Edit: if you can drop the pdfs straight in as said that’s even better. Good tip.
I guess if I had to do that and had to do it a lot of times … find a tool. If a one-off, then screen shot and put the screen shot images into PowerPoint or Keynote, then create a pdf of that page.
Thanks all. Yes it was quite easy in the end using Pages/Word. I took screenshots of the separate PDFs then put them together in Pages and finally outputted to a new PDF.
