What still bugs you about macOS's built-in screenshots?
Full disclosure up front: I make a screenshot app, so I’m biased. I’m not pitching anything here. I’m genuinely curious what annoys people who use the built-in tools every day, and what you’ve done about it.
My own list after years of ⌘⇧4:
  • The floating thumbnail. It’s handy for quick markup, but the file isn’t saved until it slides away, and if you take two in a row the first one gets in the way.
  • Markup has no blur or pixelate. If I need to hide an email address or a token before sending, I end up drawing a black box over it, which always looks a bit like a ransom note.
  • Window captures come with a huge drop shadow unless you remember to hold Option.
  • Clipboard vs file is a different shortcut (add Control), and I still get it wrong half the time.
  • No history. Once a screenshot is pasted into Slack and the file is gone from the Desktop, it’s gone.
To be fair, ⌘⇧5 fixed a lot. You can set the save folder, add a timer and record the screen, and for many people it’s genuinely enough.
So: do you stick with the built-in tools, tweak them with defaults write or Shortcuts, or did you move to something else? What was the one thing that made you switch, or kept you from switching?
I generally stick with the built in screenshot tool, I think it’s pretty good. I only wish the thumbnail would stick around a little longer. Whenever I take a screenshot, it takes me just enough time to get where I want that screenshot to go for it to be saved off to the desktop. If it stayed there a bit longer I’d be able to grab it and send it to Messages or Mail or Slack or wherever it needs to go.
Yes, this is a hassle for me too. Also, I am not too fond of the annotation tools that’s there in the default screenshot tool and the lack of backgrounds.
If my mouse appears to be moving towards the thumbnail, and the screenshot’s about to disappear, let it stay an extra half second.
@ibuys @cornchip the thumbnail is my biggest one too. A few workarounds I know of: flick it to the right to save immediately, hold Control while taking the shot so it goes straight to the clipboard, or turn off “Show Floating Thumbnail” in ⌘⇧5 → Options (you lose quick Markup that way).
The bigger problem for me is what happens after it’s gone. I regularly end up with a few hundred screenshots on the Desktop, and hunting for “the one from Tuesday” by filename is miserable. I also go back to old screenshots a lot, almost like a visual notebook, so being able to browse them matters to me as much as taking them.
@rampatra agreed on the annotation tools. Drawing a box is what I do most, and even that feels fiddly in Markup. By backgrounds, do you mean the padded, gradient look people use for posts and docs?
Small follow-up, since this thread changed what I worked on. @rampatra, Chop (the app I mentioned making) now has backgrounds: gradient, wallpaper, blur or a plain color behind the capture, with padding and shadow. Your comment is why it got moved up the list.
The thumbnail and drag-out problem that @ibuys and @cornchip raised is the next one I’m working on. Thanks for the input, all of you.
Out of curiosity, why did you choose to base the application on Electron?
@ibuys fair question, and I know Electron isn’t popular here. The reason is simple: I wanted Chop on Mac, Windows and Ubuntu, and Electron let me build all three at once.
The parts that need to feel native on the Mac are done in small Swift helpers, for example the window list for window capture and putting files on the clipboard.
The trade-off is a bigger download and more memory than a fully native app.
Nothing. It’s perfect.
Fair enough.
20 characters…
