Anyone have issues with sync using Word for iOS?
I have an office 365 sub through work and I prefer to use dropbox or iCloud for syncing (instead of Onedrive). The issue I’m running into is the confusing and flaky sync/save/share options within Word (and I believe the other iOS MS apps). If I open a doc either from within Word itself, Dropbox, or iCloud and then make changes, very often the changes don’t sync if I later open the file on my Mac. I have the AutoSave feature enabled, which should do the trick, right? Or am I missing something?
I’ve also tried to use different combinations of “Save a Copy” or “Send a Copy” to various iCloud or Dropbox folders to no avail. Most often, either option will appear to have saved/sent, and the file will show up in files/dropbox on my iPad or Mac, but the file is empty or can’t be opened (showing 0 for the file size).
Has anyone experienced similar issues and/or figured out the appropriate incantation to make this work? At best it’s frustrating, at worst I’m losing data.
