I can’t seem to figure out how to address these three files.
The bottom two are fixed in Catalina, and the google one is, well, Google…
I wouldn’t worry about them. I had 2 Apple files. I figured if Apple could’t deal with them, I wasn’t going to worry about them. As @JKoopmans said, Catalina dealt with it. As far as the Google one, the triangle with the ! indicates what the popup message says. It’s a 64-bit app with some element that is still 32-bit. Chances are it will work or Google will fix it.
