This small sound dampening box might be something else to consider if you have the space.
Amazon link
I also believe you can make one for around 25.00. I was in a seminar on audio and video and they recommended making one of these.
Amazon link
Thanks, @Brad. I might give that a try if I go for some high-quality video voiceovers. For my daily conference calls it might be a bit of overkill. I think I mainly need to get a rug over my hardwood floor and maybe put some more pillows around the room. Itâs rather bare at the moment with just a wood desk and some shelves, which is probably contributing to the hollowness and echo.
I would suggest using a walkin closet if you have great sound characteristics but usually comes at a price of bad environment controls i. e. No Air Con
Same bro, I use mine almost daily, itâs in great condition! Hereâs a pic
Itâs really amazing how well they still work. I flash modded mine and itâs faster than itâs ever been!
I was irritated by Davids explanation about the two pairs of AirPods. He said he doesnât want the noise canceling all the time. But doesnât he know he can switch to transparency mode really easy?
From someone who is similarly picky, I can say that the âtransparencyâ mode isnât anything like the awareness that regular AirPodsâ lack of a seal provides. I often forget that my AirPods are in my ears when nothing is playing, which is never something I experienced with the Pros.
