I have the same problem
That is a smart group on iOS that is hidden by default. Make sure you select āEditā from the top of the main window, which will show all the available smart groups. Ghosts is one of them there, although Iām not sure if it only appears when there are items in it.
Thank you! I didnāt realize that. I have zero items in it, thankfully, but I like the visual assurance.
@RosemaryOrchard how did you get the motion sensor/office chair thing to work? Was it simply through the Home app?
I have an Aqara vibration sensor and outlet, and it turns on just fine, but even if I set the āturn off afterā to 5 minutes it never shuts off.
I tried doing it in the Aqara app as well, and then it just turns on and off seemingly randomly while Iām working in the chair.
The vibration sensor is just stuck to my office chair - I found a spot where thereās a support for the back that goes up and that gets enough movement that it triggers the sensor regularly! The turn off after is a Home thing that I find doesnāt work too well, Iām using some custom code (not yet available) that just toggles a switch that keeps the occupancy sensor for this room on for 5 minutes after it sees this (I hope to release the code as a Homebridge plugin one day! Maybe when itās less buggyā¦)
OK, Iām thinking that I use the sensor to turn on and something else to turn off, then.
I love this kind of stuff! Iāll have to try and connect my HUE lights to some of my notifications in ICal.
Same here.
And this to make 20
