I use two keyboard layouts on my Mac, U.S. and Russian. For some reason, the U.S. layout in indicated by A
, not U.S.
. Why is it so? How is it possible to have U.S.
there instead of A
Go to keyboard settings and add then select the US keyboard. I see the “A” as being for ABC layout (I just found out that the ABC layout is identical to the US layout but for not showing a flag. I think in the latest OS versions flags aren’t displayed any more anyway).
Hi, Tom. Sorry for a long reply, I wasn’t at home. For some reason, I don’t have US
U.S. option. What I have is A
U.S. instead:
Looks like if you want “US” you will have to go with the US International layout. Or just consider “A” is “America”.
