Advice on MBP 14" aftermarket charging cables?
Hi all
I just bought an Anker 735 Charger GaNPrime 65W three-port charger to simplify my travel, hoping to use it with my MBP (14", M1), iPad Air (4th series), and iPhone SE.
But the USB-C cable I had lying around didn’t work (I know that USB-C is a mine-field in terms of features and capacity). So I thought to pair the charger with the Anker 333 USB cables instead – but their specs listed on Amazon exclude my 14" M1 MBP. Will this cable not work? Or not work optimally? What do people recommend in terms of aftermarket USB-C cables for charging the 14" MBP?
Thanks :slight_smile:
Those should charge your MBP just fine. They just put up a bunch of devices that are popular and current when the posting copy was written, but cannot put up an exhaustive list. For charging purposes, I think that USB-C is USB-C up to 3A, 60W (someone please correct me if I’m wrong). Those cables support up to 100W.
Just what I’d hoped. Many thanks!!
