AirPods Pro 2 - My kingdom for a Bluetooth headset that works
I have never been able to keep the AirPods in my ear and as a result, I have either lost them, or had my dog chew them up.
@MacSparky indicated that he got foam replacements for the silicone tips, I ordered some from Amazon and they were a big disappointment, what foam tips would you recommend?
Mine are Comply. They’re still not fantastic, but they’re better than stock.
Care to share which ones you bought before I lose another pair?
I have AirPods Pro, and I got these:
I don’t know if they’re the same as for the Pro 2, but the company has a product finder on their website that tells you what fits what:
Hope that helps. :slight_smile:
Just looked up in my amazon history and the vendor no longer exists for mine. :person_shrugging:
Replacing AirPods Pro earbuds isn’t cheap. Have you thought of ditching AirPods and getting Powerbeats Pro instead?
I tried these at one point. Whatever problem I was having went away, though, and standard are fine now.
I had a set of foam ones for my AirPods Pro - my new ones just arrived, and have been using the silicone ones that came with them. They do seem to work better than previous.
