Can you recommend some online tests?
Iâve been wearing hearing aids for about 3.5 years when I learned that my increasing tinnitus was the result of hearing loss. Mine are rechargeable and I paid more for them than my Mac Studio â but hey, itâs my hearing and connection to the outside world weâre talking about. I use both the hearing aids and Air Pod Pro 3 depending on the situation. I did the test on the AirPods and found the sound too bright for me. The hearing aids do lessen the ringing in my ears considerably, but not completely. I recently spoke to my audiologist about using AirPods and she said the reports from clients have been positive.
This is what I do as well. (I have conventional hearing aids, not AirPods) and it makes a lot of difference.
Never succeeded in getting passed the test phase of setting up AirPod Pros as hearing aids. Tried all the ear tips and none of them get me beyond this phase.
Thanks for the recommendation.
I pushed the button and now have proper hearing aids.
Theyâre taking some getting used to, especially wearing glasses and hats with them.
The sound quality is good and theyâre not as visible as I thought they would be, my Mum asked when I was getting them despite having been talking to me for 5 minutes and not noticing that I was wearing then.
My biggest trade off is that theyâre terrible for phone audio (except for calls) so Iâm going to have to work out how to carry them when I swap in my AirPods to listen to music or podcasts.
A neighbor got a grandchild to 3d print a pocket-sized case for hers
Good for you @geoffaire - Iâm sure youâll adjust quickly. As you say, glasses present a bit of an issue, but I bet you find the tradeoff well worth the inconvenience.
Thatâs not a bad shout @LisaSpangenberg i know someone with one. They provided a pouch but by cramming it my pocket, I could see the tubes getting damaged. Hard plastic may be the ticket.
Good move Geoff. I try to buy jackets and sweatshirts that have a small pocket that zips up so I can put my hearing aids in them, safely. And, a lot of the time, I leave them at home. If you do take them out, and have a separate container for them, see if you can also fit in an AirTag - itâs a good investment, and it only has to pay off once to be worth it.
Also - pro tip, I learned the hard way! - start developing a habit of tapping your ears when you get in the shower. Itâs easy to forget that youâre wearing the hearing aids, and theyâre better off not getting wet.
I donât know about the UK, but in the US you can often have hearing aids covered for loss by your home insurance. I know someone who had to provide specific coverage information (recipt) to have hearing aids included for replacement cost.
Here in New Zealand, the audiologist wouldnât give me my hearing aids until I had them insured.
Never had an issue with hats but the ear pieces on my new glasses are thicker and interfere some. Iâve listened to some podcasts on mine and it sounds ok. Havenât tried music.
That is a good shout
Iâll look for that, theyâre ÂŁ99 each to replace, so likely wouldnât reach the deductable.
The hats donât get in the way, but thereâs a rustling noise if (for example) I turn my head.
You might want to change your eyeglass frames to something that works better with hearing aids.
Two updates from me.
The Hearing Aids I have use disposable batteries (which I donât love, but I got the Aids and will be provided batteries for âfreeâ by the National Health Service so I canât complain) they donât sense a f theyâd in my ears like AirPods do so you have to open the battery compartment when youâre not using them to preserve battery life. This makes them a little more awkward to transport.
I have both AirPods Pro 2 and AirPods 4 (Without ANC). The Pros for during the day and 4s for at nighttime in bed. But the 4s fit nicely in my ear with the Hearing Aids, the Pros feel awkward to use at the same time, so I suspect Iâll be phasing out use of the Pros except for running.
I use the non pro AirPods and can wear them whilst my hearing aids are still in. If I had to keep taking them out I would lose them in an instant.
I donât have hearing aids, but I use a lanyard on my Air Pod Pros when traveling to avoid losing them.
I wear wired EarPods when traveling, for the same reason.
