AirPods Pro as Hearing Aids
I recently had a hearing test due to struggling to hear people in scenarios with background noise and have been told that Hearing aids could help me.
Yesterday I did the hearing test on AirPods Pro 2 (I did this a while ago, but it was obviously time to repeat). The Hearing test showed minimal hearing loss. This was different to my “official” hearing test which showed a more severe loss on higher frequencies, but I switched on the Hearing Aid support using the sound profile which Apple identified from my test and
OH MY GOD, what a difference.
I can now hear all sorts of things which I didn’t in the past. My Logitech MX Keys is clicky as hell, a regular dog walk this morning revealed far more bird calls than I remember hearing for ages, and simple things around the house are noisier than I remember
But I am quite self conscious about using my AirPods Pro 2 at work or in public. I see them as a barrier. I can get standard hearing aids though the National Health Service, but they’d likely use non rechargeable batteries and would be conspicuous also.
Has anyone used AirPods Pro for this use, and are the 3s any smaller? Sadly the standard AirPod 4s do not provide the same functionality.
A lot of my neighbors use hearing aids that work with an iPhone; the aids themselves are difficult to see, most of the time. Some are in fact rechargable by placing them in a special case, much like AirPods.
@geoffaire I can’t answer your question directly but as someone in a very similar situation (wondering whether time is coming for hearing aids) I would be very interested to hear experiences of hearing aids (AirPods or otherwise) in noisy settings (restaurants etc). General amplification in such a setting isn’t going to be very helpful. Apple touts “conversation boost” and other smarts, and I imagine they’re fairly cutting edge. How effective are they in real life, and in comparison to bespoke hearing aids? If they’re good I can get over the self consciousness of wearing AirPods at a table!
When my time comes, I’m changing my hair style. :rofl:
I use hearing aids as well.
While AirPods are likely to help, they probably are less helpful in the classic noisy restaurant situation than custom tuned hearing aids. Note there are some pretty competitive consumer hearing aids you can buy that arguably do as well as medical grade hearing aids.
As for being conspicuous - who cares? Anyone who thinks negatively of hearing aids is not worth assodicating with.
I’ve been trying to say this very thing tactfully in multiple drafts, and couldn’t manage it, Thank you for managing to say it so very well!
Did you use the Mimi app for your hearing test? Mine said minimal loss too.
The airpods pro 3s are a little shorter stem, but you can still definitely see them since they’re white. Wish apple made a black model. I never understood why they’re so stubborn about not offering a black color
I now wear hearing aids, and they’ve made noisy restaurants a lot more bearable, but still not perfect. They still let the noise in.
My solution is to (a) go at quieter times, and (b) ask for a quieter table. My wife and I went out to dinner on Friday night, and they put me next a wall, which meant that I could turn the microphone on one hearing aid way down (so it didn’t amplify the neighbour noise so much), and turn the other one up. It was so much better! And, even better, the restaurant manager said he’d add a note to my file - I have a file!!! - and they’ll try to get me that table every time I go.
I don’t find the hearing aid feature of the AirPods Pro to be very all that useful. I don’t know why tbh, just that if I had a choice I’d always have my tiny, lightweight expensive hearing aids on.
I want to try this out. Alas, the hearing aid feature still isn’t available in Canada after all these years.
I started using hearing aids for significant high frequency loss shortly before getting my Air Pods Pro. Did a comparison and found the AirPods could be an acceptable substitute. However the Phillips hearing aids were more comfortable for extended use and had much better battery life, easily 16 hours before needing recharging. The “color” of the sound between the two is different. The AirPods seem a bit brighter. I started wearing the hearing aids in the autumn and found I could better hear the rustling of fallen leaves better.
No, I used Apple’s implementation within the AirPods bluetooth settings
Thanks. For now at least it’s really only the noisy restaurant situation where I need hearing assistance so battery life isn’t a major issue but it’s helpful to know dedicated heating aids are meaningfully better
I just worked out I’ve been wearing NHS hearing aids for more than a decade now and I own and use Airpods pro gen 2. I have the commonest hearing loss - I have excellent hearing up to about 1500Hz where it falls off a cliff and I have very little hearing above 3KHz. As a result I do get tinnitus (which is the auditory nerves and brain hallucinating because of lack of input)
I can get through most days without hearing aids of any kind and cope reasonably well. I struggle with any kind of speech, in person or on the radio or TV without aid (It was my family complaining that I had volume levels much too high that sent me for my first test). That’s remarkably isolating. You can’t insist on quiet surroundings and only one person speaking at a time. It turns out that I’d unconsciously taught myself to lip read pretty well to cope (I was a manager in education and I did some teaching), but the tests revealed that I can’t hear the difference between sh and th or b and p and d. Without visual cues I was missing a lot of speech comprehension and ANY level of background noise quickly means I just can’t follow what anyone is saying.
Proper hearing aids (NHS or otherwise), prescribed for you after a full hearing test in a proper booth are miles ahead of Airpods. NHS ones (my local area uses Oticons) aren’t compromised. You don’t get things like iPhone direct connection, vanity features or some of the bells and whistles, but they are low noise, much better at processing the audio for your needs and work for years when I am using them at least 14 hours a day, every single day.
The airpods are fantastic for listening to music or podcasts or streaming video, with my audiogram input from the professional tests (I simply photographed the audiologist’s computer screen and typed the data points into my iPhone). The iPhone hearing test is not bad, but didn’t catch some “notches” that the professional test did, so they won’t be adapted for. Airpods work pretty well in the gym and other noisy places too, as they are better at noise cancellation - I’m amazed how well they can isolate someone trying to talk to me from the insanely loud muzak or dance track at the gym or some restaurants.
I never really cared about wearing hearing aids, let alone what anyone thought about them. Sadly, they can aid hearing and not replace it, but I don’t have to ask people to repeat so much, I can listen to speech on radio or TV or in person without becoming exhausted and I can join in with a conversation much more easily.
I’d strongly advise having your hearing professionally tested as soon as you think there might be a problem: I had no idea how much hearing I had lost by the time I did and I’d have had much less struggle and been less socially isolated if I had them earlier. We’re very adaptable and easily accept a “normal” that is way below par. If you are advised to wear hearing aids, then get proper ones prescribed and also get AirPods pro if you possibly can but I wouldn’t routinely use Airpods pro as my daily hearing aids - just the best way of continuing to enjoy music and other audio.
PS the official designations of hearing loss “mild, moderate, severe” don’t line up with everyday descriptions. “Mild” is a 20dB loss at a particular range of frequencies but that’s actually a fifth of the range of sounds that should be heard at that range - and that’s more than enough to stop you picking out a voice or sound against the background.
I very recently joined the club and am in the trial period of phonak hearing aids. They “use AI” to sample the ambient noise hundreds of times a minute (or was it a second?) to determine the level of noise cancellation needed. There’s also settings that you can switch from your phone to adjust them as needed.
I haven’t been to a noisy restaurant but was in the supermarket today. it was bustling but the noise didn’t bother me.
I’ve lost some higher frequencies as a result of chemotherapy (that’s a thing!).
I have minor low frequency hearing loss and the ENT recommended AirPods to me also. I have not tried them as a hearing aid either due to the same reasons you mention. My hearing loss isn’t that bad, so I don’t feel like that’s a step I want to take yet. But what you mentioned on your walk might be worth a try, since I usually wear them anyway in that use case.
I used the built in hearing test when I got the AirPods and the results were nearly identical to the professional test I received most recent to that. It was pretty wild.
I’ve had hearing aids since 2008. The difficulty with wearing AirPods as hearing aids is that many people assume that if you’re wearing AirPods, you’re listening to audio and don’t want to be disturbed. If I see someone wearing AirPods, I don’t engage. You don’t have the same issue with commercial hearing aids, whether seen or not.
just did a couple of hearing tests online and … seems fine? Still have tinnitus tho…
I’m know very little about ears, but my tinnitus faded away after I got hearing aids.
I remember mention this to David when I was on the FOCUSED, and I like to think my experience helped gently nudge him into investing in hearing aids.
I think there’s a hearing test you can run on your iPhone if you have a pair of AirPods Pro? Maybe try that? I suspect it’s better than the online ones. Maybe :slight_smile:
Tinitus is a pain.
Jim! You’re a genius!!!
I’m going to start wearing my AirPods Pro more often.
I love it when people don’t talk to me!!!
I don’t have an iPhone or Airpods any more, but ran a test w/ my existing earbuds + app. One of the online tests was to match my tinnitus frequency, which seems to be around 6000 Hz.
I’ll continue testing things.
