Has anyone noticed their AirPods Pro battery indicator is incorrect? Example: I put them in the case at 75%, came back half an hour later and took them out of the case (which itself was more than 50% charged) only to find they were at 63%. I see this regularly.
I see this sometimes. I’ve been assuming the contacts didn’t catch because I had that happen once (dead battery on the left one until I wiggled it to charge back up), but I’d like to pay more attention. Does your battery percentage update to a higher number later without putting them back in the case?
Yes, sometimes the percentage does go up while I’m using them
I found this on standard airpods, but a blast of compressed air sorted it.
