hey MPU,
Does anyone experience this issue with their AirPods Pro? I open my AirPods, I get the pop-up on my phone that it’s mine, etc. I listen to stuff and use it. Then after use, or even later in the day. It seems to think that the AirPods are not mine and wants to know if it should disable the tracking, etc.
Not seen that behaviour but there is a “competition” between my iPhone, iPad, and Mac mini as to which device mine are connected to when I insert them into my ears. The winner has, so far, been the device I want to use them with though.
I get that from time to time. I’m also running one of the betas. Are you on a beta?
no beta here…last night I got a phone call while getting my AirPods from the case…put them on…take the call…about 20-30 mins into the call…the “find my” chirping sounds begins randomly. Pick up the case, put the AirPods back in, my name pops up and it goes away.
Have you tried a factory reset? It’s a quick process. It’s fixed similar misbehavior for me in the past.
