Alfred 6 released
Alfred 6 has been launched: here’s what’s new. The major feature is the new Alfred UI, allowing you to create your own UI within Alfred. Take a look at the tutorials for the new UI to get an idea of how it works.
(Full disclosure: I am a moderator on the Alfred forums and simply mention this because I know there are some keen Alfred users here.)
Stephen
Downloaded and installed, odd that it didn’t give a hint that even though I was ‘legendary’ I still needed to request a new license.
Thanks for the heads up. I am virtually unable to use my computer without Alfred!
Will look forward to installing and playing with the new features.
I am also “legendary.” Let’s see how licensing works out.
Feeling a bit sad as this is the first time I won’t upgrade in ages. I’ve found the new Spotlight meets my needs and I prefer the interface, I feel nostalgic for Alfred but I won’t be going back!
Yeah, the on-boarding screen should inform us on going through the license request process. I was trying both my Mega supporter (from Alfred 4) and Legendary supporter (from Alfred 5) to no avail.
I was a little confused at the process but eventually figured it out. Put your Mega or Legendary license in the box. It will then say that you need a new license for version 6 and ask if you want to give them a “tip”. Provided that you do not, hit the 0 pounds. Then, continue. The result will be a new license for version 6.
I’m not trying to be provocative, but I find the Alfred 6 promotional page doesn’t motivate me to upgrade. I don’t really get the advantage. Does anyone know of some good videos that might help me understand?
I have built one or two custom workflows in Alfred 5 that I use many times each day. They save me quite a bit of time, but I wouldn’t describe myself as a power user of Alfred.
Can you try it for a while as an existing licensee?
I think the Alfred UI toolkit has great potential. It could make Alfred suitable for many tasks it previously couldn’t handle well due to UI constraints. But that potential is hard to realize for those who don’t use AI to generate workflows for themselves.
  • Alfred UI cannot be configured in the graphical workflow builder. You have to edit JSON files in an external text editor. An unpleasant task, especially for non-programmers.
  • AFAIK the devs have not published a schema.json yet. That thing could be very useful for manual editing in VS Code and other editors.
For those who don’t make workflows, the main (only?) purpose of Alfred UI is to make third-party workflows look better. There won’t be many third-party workflows using the toolkit anytime soon. So you might as well wait until that happens.
Or you could just give Claude code all the documentation about Alfred 6 UI and tell it to make workflows to your needs which works so well that I’m still speechless 2 days later…
This? https://www.alfredforum.com/
I’m also a “mega” supporter from years ago… but after the Alfred/Raycast episode a few weeks ago, I tried Raycast and switched over- it has a ton of really great features. Steve Robles convinced me!
Wow I still have my lifetime license of Alfred somewhere
Personally, after the enshittification of Raycast (move to electron, etc) I moved to https://tinycast.dev/ and haven’t looked back. It’s Raycast, but Open Source minus the bloat. Highly recommend Tinycast for Raycast refugees
Might give this new Alfred another try, but right now there is nothing really I’m missing from Tinycast
Yes indeed: those are the forums to which I referred.
Raycast 2 does not use Electron A Technical Deep Dive Into the New Raycast - Raycast Blog
No matter what it uses it uses way more resources than Raycast 1 and a lot more than Alfred…
Absolutely love the Alfred UI. It really needed it. Sometimes being able to pop up a field that you can then mouse over and type is just better for a given purpose. I made an Anybox plugin that uses it.
That looks really useful. Would you be willing to share this plugin?
Any security or privacy concerns with Tinycast?
I while ago, I stumbled upon https://supercmd.sh/ and thought it looked promising but with so much of my setup (search, workflows, snippets, …) being in Alfred, I haven’t really been able to test it properly (it’s the irony of having to invest substantial time to possibly make life easier or save you some time down the road). Has anyone tried it?
For now, I guess I’ll invest my time into upgrading to Alfred 6 instead.
Since it’s open source, there shouldn’t be any, no? Or at least you can point your favourite AI at the repo and ask it for any vulnerabilities.
