I’ve also looked at the roller mouse, but they seem overpriced. There’s also the issue of running out of horizontal movement. I think the pointer keeps moving at the ends. I’ve forgotten exactly.
I’ve been using the Logitech MX Vertical Wireless Mouse since June 2022. The vertical position feels more natural than a conventional horizontal mouse.
On a side note, I didn’t have much luck with the Logi Options software, but I think Logitech has since added support for the Logi Options+ (which seems better). Fortunately, Better Touch Tool has good support for this mouse and has proven to be very reliable, so I think I’ll just stick what that option indefinitely.
I tried a wired Logitech thumb operated trackball many years ago. I purchased it for an executive to use while he had to wear a metal brace that extended into the palm of his hand. I can see how some would like it, but he went back to his mouse after he recovered.
Another vote for the Kensington trackball. The three features I appreciate are as follows: adjustable trackball for cursor motion, rotation ring for scrolling actions, and chord-able input buttons for mouse-click actions. I’ve only partially tapped into the ability to set button actions specifically for different apps.
Tilt it with a shim under one side for better ergonomics.
I’m a former Logitech Trackball user and have long lamented it’s passing and being discontinued.
I currently use the MX Vertical at home as linked above, but I do carry the Logitech Ergo 575, in my laptop bag and have found it surprisingly good for a thumb trackball.
I’ve also played with a number of the Elecom trackballs on Amazon, but none of them were particular good. This was the best one I tried but the feeling of the ball wasn’t very smooth.
I recently purchased a Kensington Orbit Fusion to try - previous Kensington mice I’ve tried haven’t gone well.
Also, I’ve found a noticeable difference with trackballs on macOS vs Windows in recent years, where I’ve found trackballs working better on Windows for some reason (with no additional software).
