Is there a way to get alternative keyboards to work with the Smart Keyboard? Specifically Gamerly.
Gamerly, you say?
CultOfMac, last year: "Grammarly doesn’t work with external keyboards. Some third-party keyboards present their special extra row at the bottom of the screen, even when an external keyboard is connected, causing the main software keyboard to be hidden. Grammarly doesn’t support this, so you can’t use its on-the-fly corrections with a hardware keyboard."
As I’ve played with this a little more I’ve discovered that in work for IOS grammerly does work with Smart Keyboard. Not while your typing, but you can select txt and it will work. I’m going to have to play a little more and see where else I can get it to work. Not here obviously.
