I have an iPad Pro 12" (2018) that I have positioned below my main monitor which I have on continuously throughout the day. I use Universal Control with it, and need to access it with the mouse at least once to keep it on. I have it connected to a power source while in use in this fashion.
I also have a first generation iPad Air that I have on continuously as well, running Touch Portal. It too is connected to a power source. As long as the Touch Portal app is running it stays on.
I’ve seen several widgets that don’t update automatically and as far as I know there’s no fix. A real bummer as it makes those widgets pretty pointless.
Cases in which WidgetKit doesn’t count reloads against your widget’s budget include when:
The system locale changes.
Dynamic Type or Accessibility settings change.
For cases such as system appearance changes or system locale changes, don’t request a timeline reload from your app. The system updates your widgets automatically.
A couple of intriguing options from the docs. Any way to trigger an update to these with a recurring automation?
In StandBy, the system refreshes your widget’s display at a system-defined rate that doesn’t count against the its budget.
Otherwise, pray for this feature to reach iPad this fall.
