I’m trying to find a way to create tasks which on creation automatically have an Evernote note and a Task (in either OmniFocus (preferably) or Things 3 (2nd preference) or Todoist (ok at a push)
Ideally, this would work via Siri - and that’s where I think that TaskClone wouldn’t be the answer - I can’t see a way to automatically create a note/action which has the relevant tag to trigger TaskClone to create the Omnifocus task and note link.
Of course, this creates an Apple Reminder, but you should be able to substitute that action for one that creates a task in your reminder app of choice.
It isn’t clear exactly how you want to trigger this. I have some automation that whenever I put an article in to pocket two ifttt applets are triggered… One puts an item into todoist so that I remember to read it and the other appends the title to the end of an evernote note so I have an easily searchable list of things that I have in pocket.
This sounds similar to what you want… Creating a new note in evernote is no more difficult than appending to an existing note.
