Does anyone have a way of causing the Mac version of Google Chrome to always open to the same screen location and size when you run it? Whenever I start the browser, I immediately have to use Moom to move it where I want it (fill the left side of the screen). I’ve searched online for a solution but haven’t found anything that works. Thanks.
Looks like a problem I’d throw at keyboard maestro.
It looks like you could use some scripts too.
edit: you could look at this macro
When I record my screen, I use this AppleScript to center Chrome and size it to 1920 x 1080
set theApp to "Google Chrome"
set appWidth to 1920
set appHeight to 1080
tell application "Finder"
set screenResolution to bounds of window of desktop
end tell
set screenWidth to item 3 of screenResolution
set screenHeight to item 4 of screenResolution
tell application theApp
activate
reopen
set yAxis to (screenHeight - appHeight) / 2 as integer
set xAxis to (screenWidth - appWidth) / 2 as integer
set the bounds of the first window to {xAxis, yAxis, appWidth + xAxis, appHeight + yAxis}
end tell
I don’t remember where I found this online. Sorry.
Thank you! I will look this over.
Thanks! I’ll have a look.
