I’d like something that sync’d through dropbox or similar instead of iCloud. I use different accounts on my Home and Work ( employer owned ) macbooks, and on top of that iCloud is disabled on my work laptop.
At home I use the Unclutter app for notes, files, and clipboard history. I don’t see a reason to switch to ToT.
I like how beautiful Tot is but sadly, the Sharing button has limited capabilities. I have contacted the developers and hope they will have some enhancement down the line. Ideally, I’d like Tot to be the place I put my thoughts or notes and the drop down menu bar is the perfect place for it, BUT, I’d like to be able to then choose and file it away into Evernote, or Notes.app… a little bit like a mini Drafts app. Until then, I am currently using Evernote’s menu bar drop down, which does what I need except, it’s just one “tab” instead of Tot’s seven.
FiveNotes has been around since maybe 2016, originally called Quick, IIRC. But $4.99 seems a bit high for it (then again $19.99 for Tot on iOS is absurd). I think Tot is better-looking with greater attention to detail.
The idea of limited notes in different colors isn’t new. The 99¢ app Quick Notes has been around for a few years too.
This means that a document in Tinderbox 8.6.x can “watch” Tot and import the 7 notes. This can be configured so that any subset of the 7 can be watched rather than all 7. It is not a two-way sync – the data from Tot is imported. IMO this is good for a limited, scratch-pad type case where notes taken on iOS are imported to Tinderbox. (Or macOS, but why bother?).
FWIW, Tinderbox can “watch” an Evernote notebook, or files in a folder in the file system.
For completeness, Tinderbox also interacts with Simplenote, a free, cross-platform (including web) notes app. Surprisingly, I don’t see much mention of Simplenote here in the Discourse.
I gave up on Tot on the Mac when the most recent update got crashy. I ended up just keeping the free version of Drafts hidden in the background. Pretty app, but Drafts does more.
I like and use Apple Notes, but drafts feels faster to use (and even the free tier has Mac/iOS syncing).
Adding my appreciation for Quick Draft on iOS, iPadOS, and MacOS.
The app is a lightweight scratchpad app, actively under development, syncs reliably via iCloud, and supports markdown. I like to use the iOS share sheet to process text I write in Quick Draft.
