Technically, the old kernels are still working right now, but could be completely unusable/unstable in the next big MacOS upgrade. Google Drive, OneDrive and others has completely moved over to File Provider now, and if you are running Dropbox and already had your storage set to an external drive, as long as you don’t mess with storage settings, it continues to let you work via the old kernel rather than File Provider it seems. Someone I work with is in that position.
I work with large video files that take up more space than my 1TB internal hard drive. I recently bought an M1 Max MacBook Pro that I hoped would last me 5-6 years and I can’t afford to buy a Mac with 8TB internal storage with specs I would need.
Does anyone have any good solutions for this problem? Given my work, this is mission critical for me. With the new MacOS Sonoma being released this autumn, I feel like I am running out of time and options other than switching to Windows when the whole thing breaks. (I have never used Windows in my life and consider myself a Mac Power User, so this does feel cataclysmic lol).
I have been trailing Insync as a possible solution but I have not been able to identify if InSync is just using the same depreciated kernels that the cloud storage providers are moving away from or if they have a future proof solution.
If Sonoma breaks our ability to sync to external drives I won’t upgrade. And if/when a patch breaks Ventura I’ll switch to a Windows computer. My main computer is an iPad Pro and I don’t rely on any Apple only software/service.
Do you have enough internal storage to handle your work in progress? Do you have everything backed up both locally and offsite? If so, have you considered streaming your files as needed and using something like Panic’s Transmit to automate your uploads?
You would need to tailor your workflow to make sure everything is backed up before you upload it to Google Drive but it seems you should be able to continue with your current equipment should the worst happen.
As a reminder, a backup system keeps backup copies of files after they are deleted/lost. A sync service will sync the deletion/lost of the file. That is why we are often reminded to never consider file sync services as backups. If you need to sync your files across multiple systems and/or share them with others, then a sync service is the correct tool for the job. However, if you want to keep a backup of the files, then use a backup system (like Backblaze, Time Machine, etc.) not a sync service.
Presumably, Apple considers sync systems as applying to your current working files, which would normally be on the local file system. Therefore, for the vast majority of users, a sync system which is “properly” used would not be negatively affected by this change. However, not everyone fits the normal model so a third-party client may be needed for some users.
The third-party Dropbox client Maestral allows you to select any location for your files (and it even supports multiple Dropbox accounts, each at a different location). However, that still only applies to the local (internal) file system (mostly). As the documentation explains:
Network drives and some external hard drives are not fully supported as locations for the Dropbox folder because Maestral will not be notified of file changes in those locations. The same holds for distributed filesystems or other filesystems where inotify events may be disabled. In such cases, Maestral will only upload changes when it runs a full indexing of the local folder, for instance when resuming the sync.
So, if you are using an external hard drive in which inotify works, then Maestral should work for you. YMMV. If you are using a location in which inotify doesn’t work, then I doubt you will find any working solution for a sync service. And yes, that may mean you need to purchase different hardware.
I use an external 2TB Crucial SSD to store all my data. Nothing goes on the internal drive. If you don’t need to collaborate this works great. I’ve found no slowdown using the external drive. It has a small footprint so I can put it in my pocket and plug it into a different computer and take up where I left off. I’ve not looked back since doing this. It allows me to purchase baseline macs and saves me a ton of money on cloud services.
I do the same thing. A few years ago when I was trying to use iCloud I booted and ran my Intel Mac mini on an external Samsung SSD. I didn’t do any measurements but I didn’t notice any difference in speed.
Today I keep most of my files on an encrypted SSD and occasionally use it with my iPad Pro.
It depends which backup type you have. E.g. if you use Carbon Copy Cloner to backup to a single drive once a month, it won’t keep copies of deleted files. If you have 3 backup drives you rotate, you have a couple of months to restore.
Online services tend to have a grace period before deleted files are removed.
Has anybody tried moving your home folder to an external? I saw it from a dropbox forum thread. It also seems like most people are moving from dropbox to sync.com
I moved my home folder to an external SSD on an Intel Mac mini a few years ago. Startup may have been a bit slower but otherwise it worked normally. YMMV.
After a while I decided to install OSX and my home directory on an external SSD and stopped using the internal drive altogether. Again everything worked normally.
