Yep, odd topic for this group. However, given the problem I’m about to describe AND knowing that there are some (many?) crossover readers, I thought I would try here.
Some time in the last week or so I’ve lost ability to read any posts on the Automators forum. I see the index of messages but as soon as I click on a link it opens to a screen with no message content. In addition, the usual top level navigation with the forum name and right-side menu choices is missing. I’m observing this whether I access via the Discourse app, direct on the web, iOS, Mac and all browsers. Seems to be tied to my account in some way.
No problems with MacPowerUsers forum.
Has anyone observed the same? Any suggestions for resolution? Thanks — jay
I’ve had the same issue. I was able to see a link to the preferences somewhere (can’t remember if this showed in the app or the web). In preferences go to the interface and change the theme to default and save this. Then you can see the normal choices.
Thanks to @Cepenpark’s tip. I just realized I could grab the prefs URL from MacPowerUsers. That was the fix! I changed my interface back to Default and all is back to normal other than no dark mode. Thanks for the guidance…
For others who may be experiencing the same issue:
