BackBlaze "Splash Screen" Help
I would like to get rid of the BB “splash screen” when I restart my Mac. Whenever I restart my Mac, I get the BB “splash screen,” which I have to minimize. Is there a way to eliminate this? I can’t find an option in preferences. Thanks!
I would say I remember in the “Login Items” section in macOS preferences you could select a “Hidden” check or something like that so that the app would not display a window, but it is missing in Sonoma (and from what I’ve searched it was removed in Ventura)
Edit: this macrumors thread suggests using this app to solve this specific problem, seems to be a one time purchase and it’s really inexpensive!
I noticed that and I’m not sure why it was removed. I used that feature a lot for my “Open at Login” apps. :frowning:
I’ll take a look at Autostarter, thanks!
I don’t think Autostarter needed.
There is no longer a way to hide windows upon app launch; is there an alterative?
well, got me. what a shock. I have not “upgraded” to Sonoma.
Yea, go ahead and buy more software, if you want.
So I’m not sure how to take that! :rofl: It’s .99 but I’m not sure I’m comfortable adding a utility like that to my system. :slightly_smiling_face:
focus on other things, I would say.
I’d contact Backblaze and ask them. This splash screen should not be appearing like this.
I never see this so I did a little investigation. I don’t have Backblaze as a login item. So if you have it as a login item remove it! It is listed as an Allow in the background. It will run just fine as a pure background item.
My login items page:
I am still on Ventura on this Mac.
I think that did it, thanks! I thought I had to add BB to the Open at Login screen for it to run. Much appreciated!
