Bartender 6: Oh look, Applause finally dropped the other shoe
Have tried the SetApp beta version of Bartender6 on Tahoe and chaos! Breaks the whole machine - curser freezing, windows jumping around, etc. All goes back to normal when I Force Quit BT6. :crossed_fingers: things improve with future versions.
Bartender has been a part of Setapp. Not sure about the future, but it is still working for me 15.6.1
Same goes for me. Very buggy and annoying.
I stopped using Bartender after the first furore when it changed hands and I haven’t really missed it.
Probably because though I used it to get rid of a few superfluous items on the bar, I manly used it to reduce the ridiculously wide default spacing between the items in the default Menu Bar.
Tahoe allows you to do something about the former, and I found out how to do the latter from the Terminal (works on at least Sequoia and probably earlier versions too…) First, find out what the current settings are:
defaults -currentHost read -globalDomain NSStatusItemSpacing
defaults -currentHost read -globalDomain NSStatusItemSelectionPadding
Then set them to something better. I use
defaults -currentHost write -globalDomain NSStatusItemSpacing -int 4
defaults -currentHost write -globalDomain NSStatusItemSelectionPadding -int 4
You have to log out afterwards, I think, but then you get:
instead of the default
which is a huge improvement.
Unless you’re an advanced user, this seems to cover the main things Bartender does.
And, of course, if you are not comfortable tinkering with the Terminal, Sindre Sorhus also has a free app for adjusting spacing in the menu bar:
You can see your adjustments on the fly.
Is this a replacement for Bartender or Ice?
It depends on your needs. If you primarily use those apps to fit more items in the menu bar, this app is a good alternative.
And, very nice:
The app only needs to be run once to set the spacing and can then be uninstalled. The settings persist.
Thanks ! Knew I had seen an app that did this
Has anyone actually been able to move a third-party app from the menu bar to Control Center? It hasn’t worked for the 10+ apps I’ve tried.
Do the apps have Control Center integration?
Same here. :worried: It took me a while to figure out that Bartender 6 was the culprit.
There’s a beta version of Ice here. No issues for me so far with Tahoe.
Forget the license, Bartender 6 is destroying the battery on my Macbook Pro 14 inch M1 Pro.
https://mjtsai.com/blog/2025/10/06/bartender-6/
$20, no subscription?
add me to the list too!
Still on 15.6.1 on my recent MacBook Air M4 (which came in April with Sequoia installed by default, so I have yet to do a major version upgrade), and Bartender 6.1 beta makes the machine crazy after a few minutes, with the cursor jumping around the screen and the menu bar redrawing continuously.
Worse of it all, I cannot find a way to quit Bartender and I thus have to resort to the good old Unix CLI issue a “ps” followed by a “kill” to kill the darn process… :man_facepalming:t2:
Since I am on SetApp I wouldn’t be bothered by the new subscription-based model for Bartender 6, but since the app seems very much broken at this stage, I am definitely in need of something similar to Bartender to manage the very crowded menu bar I have…
Looking forward to tying Ice and Barbee, maybe even BetterTouchTool which also comes with SetApp.
Any suggestions or comments and experiences on these three alternatives to Bartender?
Many thanks, Luca
I have stopped using Bartender and have started to use Ice (GitHub - jordanbaird/Ice: Powerful menu bar manager for macOS) instead. I think Ice does everything that Bartender does. At least everything that I used Bartender for.
I stopped using Bartender a while back and just took the opportunity to clear out stuff from my menu bar that didn’t really need to be there.
With Tahoe, I’m evicting even more as I can now tell apps like Dropbox to pound sand. Yes, I want it running, no I don’t need constant access to it.
I now have only the time, Control Centre, 3 apps (VPN, screen capture, 1Password), plus two iStat meters. All that is only 254 points wide — a little over a third of available space on my 14" MacBook Pro.
I keep coming back to this thread and trying to figure out why I’m not having any issues with Bartender whatsoever.
Then I remember I didn’t update to Tahoe.
me neither! And yet I am having huge issues on the latest build of Sequoia on a MacBook Air M4 which came with Sequoia just a few months ago, so there is not even the excuse of some old cruft left “under the carpet” due to a major release upgrade…
I am baffled, really…
I have spent some time configuring BTT yesterday after I wrote my rant, following these instructions:
I like what I see, it’s just way too overcomplicated for my need. I might try Ice instead, when I have some time to tinker with my machine, maybe over the weekend.
L
Best feature in Tahoe by far
What does “pound sand” mean here? Is it possible to stop apps from being shown in the menu bar?
