Hello!
I’m trying to batch convert Apple docs to pdf. I’m a teacher and my colleagues all have Windows PCs. From time to time I have to share files with them, so I usually convert them to PDF.
Now this is tedious… Open pages, choose file, export, pdf…
I would like to choose a bunch of files, trigger an Applescript with Keyboard Maestro and convert them.
I’ve found a working script but it works differently:
set theFolder to choose folder with prompt "Select folder with original pages files :"
--Do it
tell application "Finder"
set theNames to name of files of theFolder ¬
whose name extension is "pages"
end tell
-- How many files to export
set item_count to (get count of items in theNames)
--Get files and export them
repeat with i from 1 to item_count
set current_file to item i of theNames -- get a file
set lean_file to text 1 thru -7 of current_file & ".pdf" -- change the originalfile (.pages) to a .pdf name
set out_file to (theFolder as Unicode text) & (lean_file) -- get the fully qualified output name
set in_file to (theFolder as Unicode text) & (current_file) -- get the fully qualified input file name
tell application "Pages"
set mydoc to open file in_file -- open input file in Pages
export mydoc to file out_file as PDF --do the exporting
close mydoc saving no -- close the original file without saving
end tell
end repeat
display dialog "done" -- Job done
Instead of letting me choose the files I have to choose a folder and it converts every .pages inside. I would rather choose my files myself, either with KM or by Applescript. Is there a way to change my script to do this?
Here is a stab. Select a file or files. Select a folder with files. Run the script.
on run {}
set theSelection to the selection as list
if the kind of item 1 of theSelection is "Folder" then
set theFiles to the files of item 1 of theSelection as list
else
set theFiles to theSelection
end if
end tell
set theNumber to the count of items in theFiles
repeat with theFile in theFiles
my exportPagesasPDF(theFile)
end repeat
display dialog "Done converting " & theNumber
end run
on exportPagesasPDF(theFile)
set theFilePath to the POSIX path of (theFile as alias)
set theFileName to the name of theFile
end tell
set theFolder to my get_sourceFolder(theFilePath)
set out_file to (theFolder) & (text 1 thru -7 of theFileName) & ".pdf"
set mydoc to open POSIX file theFilePath
export mydoc to POSIX file out_file as PDF
end tell
end exportPagesDocasPDF
on get_sourceFolder(theFilePath)
set tid to AppleScript's text item delimiters
set AppleScript's text item delimiters to "/"
set theReturn to (text items 1 through -2 of theFilePath) as text
set AppleScript's text item delimiters to tid
return theReturn & "/" as text
end get_sourceFolder
I would try the following to get your Pages files:
set thePagesFiles to choose file with prompt "Select your Pages files:" of type {"com.apple.iwork.pages.sffpages"} with multiple selections allowed
end tell
This will give you back a list of aliases to the pages files you have selected; you can select multiple files. The selection dialog will let you navigate to a folder, and only Pages files will be selectable (although all files will be shown; I don’t know how to limit the files displayed to Pages files in the standard selection dialog).
If helpful, you can add the default location <alias> modifier to the choose file statement, where the is an alias to the folder where you want your search to start. That is helpful if the Pages documents you want to convert are located in a particular place. Even if you include that, you should still be able to navigate to another folder in the selection dialog when needed.
Hopefully this is helpful. At the last it should reduce your code complexity in weeding out just Pages files.
If you don’t solve the save to pdf problem, post again and I can play around with that.
