I picked up an open box M1 Mac mini from Microcenter yesterday
I currently have a 2018 Mac mini
I’m writing to solicit advice on the best way to setup the new M1
I see my options as the following:
Migration assistant using a TB3 cable connecting the old mini to the new mini
Migration assistant using an external Carbon Copy Clone of the old mini to the new mini via USB-C port
Setup the new mini as new and then go about re-downloading software, apps, re-authenticating accounts, etc.
My mini serves as my Plex server, camera server (using the awesome SecuritySpy Mac DVR software), etc.
So, I’m not sure if all my settings for these servers will transfer over with Migration Assistant or if I’ll run into issues
In terms of MA, would there be a difference migrating mini to mini via TB3 vs. my CCC clone?
Also, regardless of which method I end up using, should I first set the mini up as new, run software update until no more updates are available and then run MA? Wondering if making sure that the old mini and new mini are running the exact same version of Big Sur is important before running MA?
I used Migration Assistant. As the old tv ad used to say…set it and forget it. There were some initial hiccups in the 1st few days of M/Mac Sur release, but most were because of Apple server issues. BEWARE of CCC (or other attempted sync from previous MacOS 3rd party backups). Mac Sur has disrupted all previous backup/sync/boot options. YMMV.
I ended up doing a clean install rather than migration
Yes, it was more time consuming, but I think I liked the idea of not bringing over years and years of accumulated code and junk
Had no issues with my Plex server using their instructions on how to move the server to a new computer
Interestingly, the only issue I had was that the first open box mini I had bought from Microcenter was activation locked (guess the previous owner didn’t restore it correctly)
Luckily, Microcenter had another open box (exact same config, exact same price), so I returned the locked one and picked up the other one and that one was, thankfully, not locked (and it had an extra two weeks of warranty compared to the first one)
