As a former Windows user I would like to use the trackpad gesture to hide a window so that when I command tab the window for the app appears vs when I click the yellow dot the app switches and I then have to open the window.
I have BTT set for âTipTap Leftâ to trigger the keyboard command â-H. You can assign any gesture an action that will fire off a keyboard shortcut.
I set âTipTap Rightâ to trigger the Application Switcher.
Is that what youâre looking for?
Good luck!
-Eric
Thanks, your suggestion was very helpful
