Another reason not to jump into the Big Sur beta as a main working machine/volume:
Dave Nanian runs Shirt Pocket Software, which makes one of the best clone/backup apps for the Mac, SuperDuper! On his blog he discusses Apple not making it possible yet to make bootable clones that work with T2-equipped Macs:
At present, it’s not possible to make bootable copies of Big Sur, even with
asr, Apple’s own built-in replication utility. As such, we haven’t released a Beta, or even an internal Alpha, because it wouldn’t meet our own requirements.So, for the moment, we’re holding back, hoping that Apple will fix the issues and allow 3rd party (or even 1st party, given
asr) bootable backups. Whileasrwas failing completely in previous builds, in the most recent one it isn’t able to back up because the system volume isn’t properly ‘sealed’ (which is ominous, since why wouldn’t a standard install be sealed, and if it’s not, why wouldn’t you be able to back it up anyway).So, while progress is being made, we’re kind of stuck waiting for the king.
In the meantime, my advice for macOS Betas remains as valid as ever: do not install a macOS Beta unless you have a critical business need to do so. These Betas, even when public, are not for general use, and certainly not for anyone who wants a reliable system for day-to-day work.
If you must install it, use Time Machine for backups for now (and, given my advice in Practices Make Perfect (Backups), on a continuing basis in addition to other methods), since it’s at a relatively equivalent Beta quality level to the OS itself and is explicitly tested and supported by Apple.
Mike Bombich’s Carbon Copy Cloner 5.1.22-b1 release notes are a little more diplomatic, but the news isn’t different:
This build continues our beta testing cycle for macOS “Big Sur” 11. In the current macOS beta, CCC will create Data Volume backups of any Big Sur startup volumes. Apple’s APFS replication utility is not currently capable of replicating a Big Sur System volume (as of Big Sur Beta 6). We’re working with Apple to develop the functionality within macOS that will allow third-party backup applications to continue making backups of macOS System volumes. In the meantime, we’re making complete backups of your data, and those backups can be seamlessly used alongside the macOS Installer or Migration Assistant to produce a bootable backup or to facilitate a restore.
In other words, no bootable backups at this time.
